-2 Imco sc max prop diameter ? >
Old 05-28-2020 | 02:21 PM
rvtransport's Avatar
Default -2 Imco sc max prop diameter ?
Anyone know maximum diameter prop I can run on -2 Imco lower with SCX upper?
rvtransport is offline
Old 05-29-2020 | 08:29 AM
I'm sure it is close to the same as a Sportmaster lower, which is 15.25" max diameter. If you try and spin a 15.5" prop, it is going to hit the cavitation plate.
endeavour32 is offline
Old 05-29-2020 | 08:32 AM
F-2 Speedy's Avatar
Call IMCO....
F-2 Speedy is offline
Old 05-29-2020 | 09:00 AM
From the center of my prop shaft to the upper housing is 8 inches. This is with a bravo 1 upper hope this helps.
fbc25el is offline
Old 05-29-2020 | 10:17 AM
I have 15 5/8” Maximus props on my sportmaster lowers
Unlimited jd is offline
Old 05-29-2020 | 11:16 AM
What cavitation plate do you have on your drives? With my -2's and the sportmaster cavitation plate, I have at most .25" of clearance between the tip of the prop and the plate, I think the gap is closer to .125". There is no way a 15 5/8" will turn on my drive without striking the plate.
The IMCO plate mounts on top of the cavitation plate on the upper vs the sportmaster plate mounting below it. Is it possible that your props were cut down to 15 1/4"? When I had BBlades lab a set of Maximus props for me last year for a -2 Bmax lower, he said the diameter would need to be reduced to 15.25". In the hub though, there are no stamps for diameter or pitch, only the BBlades stamp.
Old 05-29-2020 | 11:57 AM
Old 05-29-2020 | 11:59 AM
All the bravo quattros I can think of are running 15 5/8 diameter with sportmaster or imco lowers
