Temp hole plug
Best way to temporarily plug platform holes in transom? I have a new platform being made, but this COVID s*** messed everything up and is delaying the process. So that being said, I have a trip planned to LOTO in a few weeks, that I dont want to cancel, and still want to run the boat too, before I haul it out there.
There are six holes total. 2 (bolts) are thru the transom and the other 4 (screws) are maybe halfway into transom. Obviously I dont want any water intrusion into the transom, but also not looking for something permanent, that is going to make clean up a nightmare, when I go to mount new platform and reseal. Is it best to just fill holes with a marine silicone? Or should I fill holes with silicone and install the screws and bolts? What do you guys suggest?
Silicon or anything silicon based is going to interfere seriously with the materials you use later for a permanent fix , and that includes paints.
Use a neutral polysulfide based sealant if you have to with maybe tapered wood plugs. Yeah , it won't look too sporty but you already admit that this is temporary.
Another option would be to drill the thru-transom holes oversized and fill them with epoxy. When time to re-install the platform, just drill regular sized holes thru the epoxy then use sealant to seal the bolts. This will protect the wood even if the sealant leaks. For the holes that don't completely penetrate the transom, maybe drill them all the way thru and use the same technique described above. Obviously if you cant access the holes from inside the bilge, this won't work.
This is what I did when installing external steering and worked well.
