-   -   gear lube pump (https://www.offshoreonly.com/forums/general-q/366703-gear-lube-pump.html)
AllDodge 06-03-2020 03:24 PM
One on the left I've had for years and it use to have Merc HP lube, but shifted HP to the one on the right and put Merc new synthetic lube in the left. Used the fitting from the quart bottle pump on end of gas hose.
The big issue is finding a pump which uses a similar size line inside the tank as outside. Some of the new ones have only a 1/8 ID plastic tube.
Did just have to replace the rubber valves on the larger one this year because the lube took its toll on non-vitron, but hey it cost $5 for the new parts
https://cimg3.ibsrv.net/gimg/www.off...694811a43b.jpg
SB 06-03-2020 03:32 PM
Speedy, give me a ring. I’m well versed on diy gear oil pumps :)
F-2 Speedy 06-03-2020 03:34 PM
Originally Posted by sb (Post 4741980)
speedy, give me a ring. I’m well versed on diy gear oil pumps :)
10-4
Knot 4 Me 06-03-2020 04:31 PM
Originally Posted by cigrocket (Post 4741959)
This one has worked out for me along time. Its at the bottom of the link.
Gearcase Testers, Fillers
Holds 3 gallons and does the job. No mess
Used this one for years to do mine and all my buddy’s boats on dock.
Knot 4 Me 06-03-2020 04:35 PM
Originally Posted by speicher lane (Post 4741978)
The Gear case filler for $252.50 is just an old school metal can sprayer by design.
Mityvac which is well known for repair shop equipment sells pressure pumps that retail over $300 for refilling Transmissions... and it's just a decent pressure pot from a sprayer with a series of adapters..... trick to them all is don't run out of fluid/ add air to the refill
In the shop we had the manual pump on 5 gallon and for remote servicing - it was a good lever sprayer (oil doesn't chew up the seals like chemicals/ fuel will and flows fine in warm weather)...
It has gotten pricey. I think I paid about $170 years ago. For Bravo I drives you need their extension that threads onto the end of the quick disconnect that threads into drive or else you have to remove the zinc around propshaft.
cigrocket 06-03-2020 06:19 PM
Ha, I was thinking the same thing. The price has gone up, I guess that probably means we are getting older. I think I bought this about 12-15 years ago and it was around $125. lol
liberator221 06-03-2020 06:56 PM
AD how do you control oil flow? Install a shut off of just vent the pressure when full?
zz28zz 06-03-2020 07:23 PM
Garden sprayer here too. Mine has a pressure dump feature that's nice to have when drive gets full and starts puking.
Diamond Dave 06-03-2020 07:56 PM
I have a CDI one as well it sure makes it nice over that quart pump b.s... I bought a special machined "extension" adapter from Jeff @ Harris Performance that makes it even easier to do the Bravos than any of the ones it came with. Nice to know if the pump portion goes out I can get a new one easy lol.
Unlimited jd 06-03-2020 08:11 PM
Husqvarna pump sprayer at Lowe’s. Same pump
