Lost RPM & boost >
Lost RPM & boost
Lost RPM & boost
Old 06-25-2020 | 11:26 PM
This is when you start practicing the speech for the ol lady on why you need heads, stroker kit, etc. Ive got it down pat
mggdoors is offline
Old 06-25-2020 | 11:27 PM
TomZ's Avatar
Yup
TomZ is offline
Old 06-26-2020 | 02:25 PM
Sounds like a bad case of Covid 19.
getrdunn is offline
Old 06-26-2020 | 04:01 PM
I've always done the leak-down with piston at TDC compression stroke.
PA.WOODCHUCK is offline
Old 06-27-2020 | 06:30 PM
That's the right way.. If you get it perfectly at TDC, the eng won't rotate but that can be difficult to do. Usually takes me a couple of tries. There's a replaceable orifice between the 2 gauges of the differential press tester The size of the orifice is determined by the eng size. If it's not the right size orifice, the differential readings will be off.
However, assuming the compression is a bit low due to bottom end leakage, I would think it would still produce some boost at 4k RPM. As mentioned prev, I'd try a new blower belt before tearing into the eng or blower..
zz28zz is offline
Old 06-27-2020 | 11:47 PM
I put a scope in the cylinders to see the pistons. Didn't see any holes but they did seem carboned up. Did the overheat cause the rings to stick?
Itsallgood995 is offline
Old 06-28-2020 | 01:45 AM
Put a new blower belt on it and go run it and report back.
If pistons are have significant carbon build up, its from a rich condition. That rich condition could be from dumping in fuel at WOT and not making the rpm to use the fuel due to lack of boost.
Griff is offline
Old 06-28-2020 | 11:53 AM
Check or replace your temperature sensors
Did you replace the thermostat ?
1) Engine Coolant Temperature Gauge Sender
2) Water Temperature Gauge Sender
Jamesbajaboss is offline
Old 06-28-2020 | 04:07 PM
The overheat condition can cause the rings to lose their tension. If you are truly seeing 40-50% leakage past the rings, they have lost their seal. Pull it out and tear it down.
snapmorgan is offline
Old 07-01-2020 | 04:09 PM
Any update OP?
getrdunn is offline
