Idle problem
My symptoms have changed slightly it now wont idle at all low down even holding it on the throttle . with throttle closed turning the key it starts easily every time idles good for 4 seconds then the MIL alarm goes and it cuts out.
After this there are no codes thrown up. It can be kept running by opening the throttle to about 25% but on reving the engine is holding back at about 4000 rpm symptoms as though its not getting enough fuel.
My fuel pressure sensor on the throtlle body has grey , black and green wires not blue as in the wiring diagram ? Also the main ECM plug wire positions are COMPLETELY different from the wiring diagram ??
Agree it its TBI then there is not a rubber line. If its MPI then it does. If its carb then there is no IAC
The serial number is the issue as SB mentioned: L09691
A Merc number is a number, a letter and then 6 more numbers. Looking up using 0L09691"X" all are carb motors
There it is the pesky little "2"
Not L09691 but L096291
Yes this is a TBI
https://www.mercruiserparts.com/5-0l...-0l012052-thru
Yes this is a TBI
Yes this is a TBI
Yes this is a TBI
can you tell me what is the purpose and how does the circuit breaker that is on top of the engine work ?mine is rusty but it wont come appart , can i test it ? it show continuity.
Okay, so the boat now has a 5.0 vortec longblock and the boat originally had a 5.7 vortec longblock w/tbi ?
oh boy. That’s not so good.
The ecm has no clue 50cid’s where taken away. So that’s another issue. Are the injectors same on 5.0 vs 5.7 ? Doubtful. Will look that up in a bit.
When looking at parts for Block and Pistons there is 2 listings each which would indicate for me that it can be either
