502 mag mpi no start >
Old 07-02-2020 | 09:18 PM
Default 502 mag mpi no start
boat was running fine, anchored off for a while and went to fire it up and it just clicked. Got it towed home and found the clicking was coming from the solenoid on top of the motor. Replaced that along with the two relays and now I'm getting nothing. Everything is tight and batteries have good connection. Fuel pump turns on but that's as far as it goes
Vsyx is offline
Old 07-02-2020 | 11:43 PM
Just a thought We had this happen to us last weekend Found corrosion on starter connections Cleaned them up Vrrrrroooooom!
MooresWarlock is offline
Old 07-03-2020 | 08:26 AM
Get a test light or volt meter and test for voltage in/out slave solenoid(which U replaced) along with at starter.
PA.WOODCHUCK is offline
Old 07-03-2020 | 08:35 AM
Mine vapor locked last weekend. No fuel press. Crank and bleed. WOT and it finally came to life. First time for me.
wuzzgunna is offline
Old 08-09-2020 | 11:30 AM
Workshop manual gives many scenarios and their possible causes.
Tractionless is offline
