Trim Position Sensor >
Old 07-05-2020 | 07:46 PM
Default Trim Position Sensor
Is the outdrive trim position sensor a simple potentiometer I could check at the indicator with an analog meter? The indicator operates erratically.
26 Outlaw Bad Influence is offline
Old 07-06-2020 | 08:36 AM
Yes, you can use an Ohm meter to check a sender if it only has two wires. You can use a voltmeter to read the output signal of a three wire sender by connecting between the blue and white wires with the ignition turned on.
GF?
Got Freedom? is offline
Old 07-06-2020 | 01:02 PM
Default Sensor
I’ll check it as soon as I can. TY
