what is the reasoning >
Old 11-11-2002 | 04:03 PM
283CHECK
Question what is the reasoning
for changing the oil during the winterization process instead of at dewinterization?
Old 11-11-2002 | 04:10 PM
Tinkerer's Avatar
You should allways change the oil in the fall so that the contaminents dont sit in the engine all winter.
Tinkerer is offline
Old 11-11-2002 | 04:12 PM
283CHECK
contaminents? will these hurt/pit the cylinder wall,pistions or settle to the bottom of the oil pan?
Old 11-11-2002 | 04:15 PM
CigDaze's Avatar
The reason is twofold. First, you want to eliminate as many as possible suspended particles and contaniments. If left in there, it will be sludge by springtime. Second, used engine oil becomes very acidic after it contains combustion byproducts. This acidic oil will contribute to corrosion.
CigDaze is offline
Old 11-11-2002 | 04:38 PM
cig1988's Avatar
I will change my oil before winterization substituing 1 quart of marvel mystery oil. Will change oil again in the spring. Seems to help. When I disassemble the engine for routine maintenance, everything looked as good as the day it was assembled.
cig1988 is offline
