-   -   Hp500efi rebuild (https://www.offshoreonly.com/forums/general-q/367375-hp500efi-rebuild.html)
riverrunner242 07-08-2020 10:08 PM
Hp500efi rebuild
I recently bought a hp500efi and looking to build a 650 hp 540ci out of it. I'm curious what other guys are running. Retuning the efi system, carb, or installing aftermarket efi system such as holley. As always I appreciate all the help I can get.
Griff 07-09-2020 12:38 AM
Stock EFI intake hits a wall around 600-620hp
F-2 Speedy 07-09-2020 08:23 AM
These 540's made 630hp, thats all the intake will support
https://cimg2.ibsrv.net/gimg/www.off...0c928d25fd.jpg
riverrunner242 07-09-2020 08:29 AM
I'm assuming bigger injectors? Any idea what I would need to use if I decide to use the efi
SecondWind 07-09-2020 08:41 AM
This can be done for 13K, looks like more power available with added services.
https://cimg4.ibsrv.net/gimg/www.off...9ffc5a0ae1.png
F-2 Speedy 07-09-2020 09:43 AM
65 lb hour injectors, stock TB and intake runners, custom grind double swap cam and AFR heads
articfriends 07-09-2020 01:29 PM
a 525 style flame arrestor with a monoblade tb properly tuned will help a built 500 gain about 15 to 20 hp on top and more peak torque. The FA's are super expensive at 765$ each though. You CAN buy the 525 throttle blades for 50$ to bore out IF you know a competent machinist . hardin or somone sells a 525 fa for 600$
articfriends 07-09-2020 01:31 PM
Did you have the FA's on when you dynoed? I saw a restriction from them at less hp on my dyno
F-2 Speedy 07-09-2020 01:47 PM
yes, full dressed with CMI sweepers, maybe we should of taken them off and do a pull, but we didnt
xlint89 07-09-2020 09:38 PM
I honestly thought someone would have suggested selling the HP 500 and just buying a 540 as opposed to conversion.
A lot less work and prob cost less in the long run too.
https://www.ebay.com/itm/MerCruiser-...QAAOSwjL5ZFdX3
https://www.ebay.com/itm/540-Bulldog...IAAOSwnK9ZVqxK
https://cleveland.craigslist.org/bpd...145891904.html
Just curious, what did you buy the 500 HP for? I've got a 502 MAG (black engine) that I would ultimately like to upgrade and a 500 HP EFI would be what I'd want or replicate for reliability.
