What RPM should I be at WOT? >
Old 07-14-2020 | 08:07 AM
SB
Mirage have same diam as Mirage + ?
Mirage Plus 21” pitch has a 14 3/4” diameter. This diameter is huge for a single engine boat w/5.7l engine. Been there done that.
SB is offline
Old 07-14-2020 | 08:39 AM
not sure if it’s a mirage or mirage+ but here is the best picture I have of it on hand. Does the diameter look too big?
1986Scarab1 is offline
Old 07-14-2020 | 08:41 AM
Not in front of the boat but this is the best photo I had of my prop. Does it look too wide?
Old 07-14-2020 | 12:39 PM
I do not think that is a Mirage or Mirage Plus prop.
Griff is offline
Old 07-14-2020 | 02:34 PM
Griff you're right!! My bad!
Now that you called it out it came to me, it's a mercury "vengeance" prop, not mirage! Don't know how that compares diameter wise but it is a 21 pitch prop.
These are the specs, pretty sure this is it.
Mercury Vengeance (13.75" x 21") RH Propeller, 16318A46 48-16318A46
ooking forward to everyone's thoughts/feedback! Thanks!
Old 07-14-2020 | 03:15 PM
SB
Have not tried those before, but that's a good diameter.
SB is offline
Old 07-14-2020 | 04:33 PM
8000 will sound like nascar be sure to post the video here
boostbros is offline
Old 07-15-2020 | 12:40 AM
They do make Mirage Plus props in as small of a diameter as 14.375"
Griff is offline
Old 12-24-2020 | 08:52 PM
Default Rpm limiter
I am wondering what the rpm limiter is set to on the 2012 4.3 liter and 3.0 liter tks. Also, what does the limiter do when you hit the limit. I just got both engines and wondering what the limiter is compared to the WOT.
Aidan Tonchev is offline
Old 12-25-2020 | 08:45 PM
The Merc rev limiters are set at 150-200rpms above the max recommended WOT. Not sure what the recommended WOT range is for your engines, but they should have a label on them indicating the WOT rpm range.
Griff is offline
