Had a Rocker Fail >
Had a Rocker Fail
Had a Rocker Fail
Old 08-28-2020 | 03:40 PM
  #41
Anyone have any experience with the Yella terras? If I recall Rookie saw them at the PRI show and claim to be pretty decent at a favorable price.
getrdunn is offline
Old 08-29-2020 | 09:08 AM
  #42
seafordguy's Avatar
Originally Posted by dunnitagain
We Spun those same rockers 9800 in Cup Motors , But yes , we only set adjuster out max 1 Turn, or we changed pushrods , Also the lock nut is 22 FTLB .
If you ran the adjuster out 2 turns , the ****ers woudnt make it off the dyno. But we ran them 2500 miles in race engines . I forget the amount of cycles , Max Rpm 9600-9800.
and Yes we had those cool ass torque wrenches to adjust them with.
Yes - I'm not going to run them next year as is. Being out of the range worries me so I need to rethink my plan. Certainly need new pushrods and might switch to the steel lifters.
The torque wrench was money well spent. Really made the job easy - putting plugs back in and valve covers on was the biggest pain.....
Put about 75 miles on it this weekend with no issue, Other than a small oil leak. I reused the blue valve cover gaskets but one must be leaking a little.......
seafordguy is offline
