468 engine build cam option
wider 112 Lsa compared to 110 of the zz502 cam. 731 has more lift and more duration. I am going to use the zz502 cam, stainless Marine exhaust with slightly extended 3" Taller risers.
good info! Just dont understand how it is possible with small duration cam like this, there is many cams that guys are using here with more overlap. What I know is that in zz502 crate engine the cam is only 2 degrees advanced 108 degree icl. Hp500 cam is almost identical but has more lift, 110lsa, 6 degree advanced, 104 degree icl.
Something else that can play a role is ignition timing. Modern oem vehicles retard the chit out of the timing on cold starts, because it heats up the catalytic converters in a hurry. Having too much timing advance at idle, takes away alot of heat from the exhaust, as well as pressure.
Back in the day, a common cause for an engine running hot at idle, was timing was retarded. It would make the headers/manifolds really hot while idling.
Next time youre playing around setting timing, make a mental note of the exhaust sound while retarding or advancing the timing at idle. Youll find retarding it say to 10* btdc , the exhaust has more "bang" to it, and advancing it to say 30*, it gets a little quieter, and a little smoother. Its simple. The later you fire the plug, the closer the explosion happens relative to exhaust valve opening. This helps put pressure into the exhaust, helps heat the exhaust valve, and helps burn off condensation dripping in the pipes. Alot of guys run alot of base timing to acheive a smooth idle, but sometimes that may cause a reversion issue. Less timing will also require you to have the throttle blades opened more to achieve the same idle speed, which in turn lessons intake manifold vacuum, and in turn results in less reverse "suction" during idle overlap.
The following 2 users liked this post by MILD THUNDER:
Baja Rooster (08-21-2020), sonicss42 (08-21-2020)
Ok we’re getting a lil side tracked maybe. I agree with my original compression figures being way off. I’ll have to get some small dome pistons. Prolly -12cc domes, ish. But my compression goal will be in the 9.5:1 range to stay on pump gas. Still need to figure out which heads I got for CC. 110/118 chambers. Not sure yet. But
Back to good cam selections. Preferably with some dyno proof of power output.
These wiseco pistons are a good deal. Ive used them in a 540ci, and a 516ci. Usually you can find them around 500 for a set and they come with a file fit plasma moly ring set.
https://www.summitracing.com/parts/wis-pts514a6
