Cam
Built a 496 with EQ heads and this roller cam. Running gill exhaust and the mercruiser wet risers. Wondering if anyone can tell me if reversion will be an issue? Was going to modify and make dry but if I don’t have to I won’t.
https://cimg5.ibsrv.net/gimg/www.off...5d6f95d104.png |
whats the lsa ?
Original Hp500 had same exhaust but smaller cam with much less overlap and had reversion issues. Merc then came out with a much taller riser to create a larger rate of fall to combat this, merc still provided instructions how to clear out after extended idling.
Updated version: https://cimg7.ibsrv.net/gimg/www.off...07ce82345.jpeg |
Looked it up for the OP.... Looks like it's a Howards hydraulic roller - 114 LSA.
Originally Posted by f-2 speedy
(Post 4753606)
whats the lsa ?
Looks like I will have to modify and make them dry. Thanks guys.
is the rotating assembly cast or forged
(Post 4753627)
| All times are GMT -5. The time now is 02:11 AM. |
