NXT/#6 dry sump filling >
Old 08-25-2020 | 05:16 AM
neva satisfied's Avatar
Default NXT/#6 dry sump filling
Is the method for filling a NXT/#6 dry sump drive the same as a normal bravo? "fill from the bottom until it comes out the vent". Thought I read somewhere you had to turn the prop shaft as you filled it but not sure.
neva satisfied is offline
Old 08-25-2020 | 06:57 AM
jbraun2828's Avatar
Yes the same as a bravo for normal oil changes. When you change the filter you have to rotate the prop shaft like 80 times to prime everything
jbraun2828 is offline
