Lifting points on 454 mag mpi >
Old 08-31-2020 | 06:47 AM
Default Lifting points on 454 mag mpi
Got a 99 454 mag mpi that I need to pull for a drive coupler replacement. From the one pic I have I can't tell if there are any lifting points on it. Where should I be lifting this engine from?
Also, what else should I do while I have it out. Was going to do impeller, maybe gimbal, and clean up the engine compartment with some degreaser.
Thanks,
Bones
CapnBones is offline
Old 08-31-2020 | 07:08 AM
There's a hook right on the front by the Drive reservoir. You may need to bolt another one on to the back of the starboard cylinder head.
LakeHuronPower is offline
Old 08-31-2020 | 07:32 AM
Originally Posted by LakeHuronPower
There's a hook right on the front by the Drive reservoir. You'll need to bolt another one on to the back of the starboard cylinder head.
Bahaha, sure enough, I can see it in the picture now! Thanks
Old 08-31-2020 | 08:13 AM
There should be another one right next to the cannon plug
Unlimited jd is offline
Old 08-31-2020 | 08:34 AM
Good deal, sounds like it shouldn't be too bad, just need to find a friend with a forklift or something to stop by and pull it.
