Holley EFI Timing tables. Can anyone share what they run
This post could not have come at a better time, I am just dropping in my fresh 509 with a 9.2:1 compression on the stock iron heads fitted with Inconel valves. It has an Isky cam with these specs:
I have no clue what timing to run on a Big block I'm more in tune with an LS and what heat range plug to start with???
And for knock sensors, do these blocks even have provisions for that? Mine is a brand new GM performance 502 block as my stock one cracked in a water jacket.
- Racing Cam
- Hyd. Roller
- Valve Lift Int/Ext. 0.553/0.578
- Valve Lash Hot Int/Ext. 0.000
- ADV Duration Int/Ext. 275/284
- 0.050 Duration Int/Ext. 228/238
- Lobe Center 112
yeah sorry chaps thought i was replying to my own thread regarding the sniper spark tables. Im not sure but 25 degrees is an insane amount of timing for marine use.. id say starting round 12-16 and maybe 28 at cruise /3000rpm and above would be a starting point. Ran a similar tune ona stock gen4 merc and it was screaming. 50mph vs 40 original, and the power is just on tap, like a double pumper almost.. Real nice aggressive -
