Closed cooling for engines over1000hp >
Old 01-05-2023 | 12:09 PM
  #51
Originally Posted by ICDEDPPL
So you`re using something designed for exhaust gasses and filling it with salt water? I imagine most are doing closed cooling because of salt water .. salt water eats aluminum for breakfast, doesn`t seem like a long term solution.
Yep it's 100% stainless. It's designed to have water one side, and 600 deg C exhaust gas at 60 psi on the other. The build quility is far superior to and marine heat exchanger you will ever buy... Jas
ecuchips is offline
Old 01-05-2023 | 01:13 PM
  #52
I may be missing something but do I see 4-6 holes? What are those big holes on the top?
Wouldn't in be one in for raw water, one out for raw water and the same for engine water?
Do you have a sketch on how you are hooking this up?
Originally Posted by ecuchips;48549
24
Wildman_grafix is offline
Old 01-05-2023 | 01:25 PM
  #53
scippy's Avatar
2nd on the sketch layout.
scippy is offline
Old 01-05-2023 | 01:43 PM
  #54
Big holes on top are engine water in and out. Fittings to be welded on once engine is in and orientation is figured out.
-12 fittings on front are seawater to exhaust manifolds.
32mm fitting on the back is seawater in.
2 X 25mm fittings at back, 1 for a pressure releif valve as it's making 35psi water pressure. That will dump on top of the drive...
1 for a feed to fill my balast tank up front via a tap the co driver controls. When it's opened, the pressure releif valve will close or reduce at least...
Jas
ecuchips is offline
Old 01-05-2023 | 08:56 PM
  #55
Default Heat exchanger
ecuchips is offline
Old 01-05-2023 | 10:17 PM
  #56
scippy's Avatar
Starting to see the whole picture now!....have you figured out the placement the glycol tank & circulating pump yet?.....can you tell me the length of the cooler & the end dimension ~3" x 3" ??? or so.
Seeing a lot of different coolers & Trying to figure out what cooler would be best for my setup.....I'm running n/a 700 hp BBC's .......what dd15's would suit my needs?.....No doubt, there's a bit of
fabrication involved probably not for the non-wrencher DIY-er, but I do weld (a bit) never tig on ss before, but I can throw it down & have a go at it if I choose .....to me, running in the ocean and
having already eaten up 2 pairs of Imco power flow manifolds is not cheap.......I can pay 5K on a pair of CC systems from Harden - or- go cheap on the $$ and big on the labor try!
scippy is offline
Old 01-06-2023 | 07:51 AM
  #57
I understand now. I looked on E-bay and there are a few of these there, it would be nice when I re-power. With Scippy, can you post dimension? I will only be around 600HP NA.
Old 01-06-2023 | 12:19 PM
  #58
Thumbs up
A smaller one would work good as a oil or trans cooler .
ICDEDPPL is offline
Old 01-06-2023 | 02:29 PM
  #59
I wonder if the larger one would work well enough to run the engine and exhaust?
underpsi68 is offline
Old 01-06-2023 | 05:26 PM
  #60
scippy's Avatar
I believe a full system is engine and Manifolds, but not risers.
scippy is offline
