I don't have those plugs either. The longer one looks like some type of drain.
I've never had any water in my Stelling boxes, but have heard of water getting into other peeps Imco boxes. |
Any chance someone tried to plumb a way to grease the carrier with the first bolt holding down a component to the box?
No idea for certain - just throwing it out there... |
Thanks for the replies guys, I'm going to investigate it further this weekend.
Dean |
Originally Posted by Griff
(Post 4775511)
Originally Posted by Keith Atlanta
(Post 4760169)
In your picture, there is a gold "hub". In my application, the hub is bolted to the flywheel and the u-joint 4 bolts bolt directly to it. So, yes, its direct to the flywheel. Metal to Metal. The key to these boxes is to get the carrier aligned with the driveshaft and keep it good and tight. Once its dialed in they last many years. There is a company that makes that gold coupler out of a polymer called Globe Products - but I never got around to installing one.
Originally Posted by tmmii
(Post 4775601)
Getting ready to get mine on, how do I do the alignment?
Originally Posted by JaayTeee
(Post 4775653)
There’s shims that go between the carrier and the box, if it’s currently assembled, check it with an alignment tool and see where it’s at..... it one of those things that should only have to be done during the initial assembly when it was new.
Awesome that sounds pretty easy. Thank you. |
Those aren't original from Stellings. I drilled holes in the bottom of mine and installed plugs in them just in case water was to get in there. It woould be a real PITA to get it out of there. I dont know if I'd be comfortable with those caps on there without safety wore or something on them?
| All times are GMT -5. The time now is 09:41 PM. |
