What is the difference in these two engines? >
Old 10-07-2020 | 03:07 PM
Default What is the difference in these two engines?
What’s the difference in these two 350 MAG MPI engines?
87MagnumII is offline
Old 10-07-2020 | 03:19 PM
If we knew the serial numbers could determine better
Both are 300 hp
Top is newer and probably has Gen 3 cool fuel module and HVS distributor,
Bottom probably cool fuel Gen 2 and EST ignition
AllDodge is offline
Old 10-07-2020 | 03:40 PM
Both are 300 hp
thanks. The serial numbers say the bottom is a 1997 and the top is a 1998 or newer. Why does the older one seem to have a single plane style intake on it?
Old 10-07-2020 | 04:35 PM
1998 was the change over year
The high rise intake is said to have better low end torque. That said, the reason to change from one thing to the other in most cases is for a cost savings
My self I would take the older motor because of EST ignition and MEFI-3
AllDodge is offline
