Marine power 502 pfi. Looking for injectors.
those look like mercury part numbers. Not sure if marine power used the same? Pfi probably stands for port fuel injection
It is probably same gm 8.2 engine with any difference in throttle module and injection systems
Came up as 3rd result when I seached ‘Marine Power 502.’
http://marinepowerusa.com/wp-content...anual-1993.pdf
Also, if your in the states you can send to a good injector place like member ArcticFriends. They can go thru them and if replacement needed, will probably have a good teplacement.
it is great idea about injectors remanufacturing.
Already downloaded.
but it is mpi, not pfi.
Do you think it is the same?
Another problem - 0730500 no longer available 😳"
