K-Plane restoration
Have fit 280T K-planes to ski boat, although had to cut down the transom mounting plates, and fabricate new stainless actuator mounts (which not sure whether to polish, chrome, or paint )
need to decide whether to powder coat, polish the aluminium or 2-pak the K-planes How well do they stand up to paint or powder coating still undecided on colour of hull whats suggested ? https://cimg0.ibsrv.net/gimg/www.off...e279d69f10.jpg |
I single stage painted my tabs and drives in 2010 and they held up great. I have seen an instance that powder coat has came off in a sheet on a drive.
https://cimg3.ibsrv.net/gimg/www.off...c8b2152df5.jpg . https://cimg5.ibsrv.net/gimg/www.off...4ee60ec21d.jpg |
Powdercoat or paint will hold up just fine. Both have plus' and minus'.
You really should not powdercoat the rams unless you disassemble them though. |
the transom plates were corroded around the actuator mounts, so when reduced in height to fit transom position the plates don't look to bad, had to redrill the 2 holes into transom plates, and weld up the hydraulic trim bolt holes
not sure whether I'm going to replace the seals in actuators, they look fairly easy to do if I can order the correct kit There are few marks on ram bolts, however polished the shafts with 1500 grit I might give the painting a go cheers Brett |
| All times are GMT -5. The time now is 03:48 AM. |
