Do turbo engines have reversion issues? >
Old 11-07-2020 | 04:19 PM
Default Do turbo engines have reversion issues?
Was wondering about reversion on a twin turbo application
what cam profiles do turbo engines like?
i was thinking turbo with dry tails wouldnt be too loud as the turbo breaks up and lot of the exhaust sound waves. Thanks for Any info you can share, RM
iliveonanisland is offline
Old 11-07-2020 | 05:06 PM
Dude, great question...
Keith Atlanta is offline
Old 11-07-2020 | 05:57 PM
In most muscle cars a turbo will make great power with a stock cam profile. I would think that would remain true in boats also.
ttuton is offline
Old 11-07-2020 | 06:45 PM
What I’ve been told is that the better an engine flows air (cam & heads) the more hp it will make with the least amount of boost
you know if blower cam grinds work well in turbo set ups?
I think the LS engines are much better platform than the old school sbc engines. The LS3 rect port heads flow 298cfm. Chevy CNC’s the ports and combustion chambers On some of the hi hp LS engines
The 6.2L iron block engine is the hot set up for a cheap bottom end and I would port the stock heads and run the oem intake and throttle body.
garret makes 47-55mm water jacketed turbos they will support 700hp! The air boat guys are getting 1500 hours out of a top and at 650hp in n/a on the ls engines. And 3,000 hours on a bottom end.
I think turning a prop on an airboat is probably pretty similar load to a boat.
Old 11-07-2020 | 09:43 PM
I would be great if you learned how to put your engine tech questions in the CORRECT forum
Griff is offline
Old 11-07-2020 | 10:02 PM
I didn’t know there was a tech forum. Lol
Old 11-08-2020 | 06:32 AM
This guy doesn't seem concerned about reversion ... (thumbnail is cropped. 1,700 hp, not 700!)
Oh, nevermind, he's running full open dry exhaust. Still a cool video and how I found the CleetusMcFarland channel which is mostly car racing. He has a 7 second 1/4 mile "streetable" Corvette. You can tell he's not a boater when he opens his mouth wide at 100+ mph.😉
thirdchildhood is offline
Old 11-08-2020 | 06:57 AM
[QUOTE=iliveonanisland;4764785]What I’ve been told is that the better an engine flows air (cam & heads) the more hp it will make with the least amount of boost
This is a true statement, but not what you asked. You asked if turbo engines have reversion issues. Based on how well a turbo works in a auto platform with the crappy cam profiles used to pass emissions, I would think those same cams could be used in a boat and not have reversion issues.
ttuton is offline
Old 11-08-2020 | 08:38 AM
[QUOTE=ttuton;4764810]
i probably should have asked if the turbo smooths out the pulses of the engine to prevent reversion issues.
If you have 4 cylinders feeding an exhaust manifold the turbo will always be spoiling some as soon as you start the engine correct?
There by always moving the air in the tails out of the tailpipes so reversion can’t happen once the turbos are spinning.
I wonder if on initial start up before the turbos spool up enough to prevent reversion could the water enter the turbos?
Old 11-08-2020 | 08:44 AM
mild oem cams I doubt would cause reversion issues but aren’t we all looking to make as much hp as we can reliably? I’m wondering if the turbos have reversion issues so I can run as much cam ass possible to make as much hp and tq as possible with the combination.
