Mercruiser 496 proplem >
Old 12-26-2020 | 09:47 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Those plugs are toast; yes some worse than others.
How many hours on the engine?
Sydwayz is offline
Old 12-26-2020 | 09:50 AM
Seeing a bit of oil burn, some rich and some lean
Have injectors cleaned and flow tested
AllDodge is offline
Old 12-26-2020 | 10:33 AM
About 480 hours on engine.
I changed the spark plugs last winter for 2020 season. So they are barely 1 year old.
Okey thank you. But the plug that is all black, feels that it is something wrong there
JohanSweden is offline
Old 12-26-2020 | 01:35 PM
Could need valve seals
AllDodge is offline
Old 12-26-2020 | 01:36 PM
Two more pictures:
Port side
Starboard side
Old 12-26-2020 | 02:02 PM
On what spark plug/s do you see burned oil?
Old 12-26-2020 | 02:45 PM
Not counting the oil on the threads looks could be 7 and 6, but latest pics not as much, but there is some kind of by product. Is that rust down inside 5
AllDodge is offline
Old 12-26-2020 | 03:42 PM
okey, yes it looks like rust down inside. Dont know what the wite stuff is.
Heres some nearby pictures, also nearby picture of the 3 plugs on port side, also with rust inside.
Took the boat up in september and it have been stored in my garage tent since then.
Old 12-26-2020 | 04:16 PM
From my rookie opinion,
has injectors been serviced
leak down/compression test
Is it stock exhaust reversion issue?
for only 1 season on plugs U got deeper problems.
PA.WOODCHUCK is offline
Old 12-26-2020 | 04:27 PM
Have you pressure tested your exhaust? Could be a water leak and the white stuff salt.
My plugs looked like that except the white stuff when my CMI´s gave up. Also as mentioned before, check compression.
SCANDINAVIAN is offline
