Help Me Out - wiring in a kicker solenoid
As mentioned normally closed relay
When power is applied (vian Neutral switch) the relay opens, no power going to solenoid.
Shift into gear , relay loses power and activates solenoid.
..bring in power from ignition switch
Good thinking out of the box, let us know how it turns out
Also found this which would have probably worked once properly mounted on the shift bracket but Liberators solution is the easiest......
This is available in both Normally Open and Closed variants and the closed can carry 5A 12V which I would assume that solenoid is under....
https://www.littelfuse.com/~/media/c...-datasheet.pdf
Hoping this Works and it has enough force to just barely raise the idle
There's another way around this. You need more initial timing. Depending on your ignition system this can be easy to do and keep your total timing as is or it can be a pia. But it would solve the problem.
Timing is locked at 32*.......
I'm hoping when I do go to FI to use Holleys distributor that can manage timing. I've read that advanced timing at startup can be hard on starters.....
You could use a MSD spark retard to pull timing out when cranking. I think they are active below 500rpm. I used them on my 565s when I ran locked timing at 34 deg. I believe they pull out 10 or 20 deg depending on what setting they are on
on the carb tuning,,you used the vac gauge to get the best reading,good,,you then have to take 1 idle screw and start turning it out,a little at a time.that should get you to idle in and out of gear.I do this for carbed blower motors all the time.strap it to the dock and tune away.
If you want the solenoid to work as advertised use the relay.
Think about what the solenoid is doing. It is tickling your throttle. Old school carbureted blower motor guys use to have to learn how to drive their boat around the dock. If you shifted your engine would die unless you tickled of just gave it a tiny amount of throttle immediately after shifting. You then could bring the throttle back down and everything was fine.
I think the solenoids are a joke. You just need to practice using the tickle method. I’ve taught May new offshore boat owners how to drive them.
i think you can do this with a bosch 5 pin relay. At rest pin 30 is connected to 87a and when energized pin 30 connects to 87. You can wire the relay to be 12v switched or ground switched depending on how neutral start switch works. You would only use 4 of the 5 pins on the relay. Just make sure the power input(pin 30) is key on only.
I was thinking of doing the same thing. I ended up switching to Daytona Sensors ignition from MSD. Worked as good as I hoped for. You can set a desired idle rpm and it adds timing to control rpm. My carb motor runs like EFI now. If you need details, PM me and I can send you the timing file I created. This will work way better than bumping the secondaries.
