Bbc 509 procharger D1? >
Old 01-03-2021, 04:54 PM
mcollinstn's Avatar
4 psi should be plenty safe, even with mid-octane levels. At 4psi, your valves are fine too.
keep total timing under 35.
You are borderline on requiring an intercooler.
If you do choose to add a decent cooler, you can probably increase boost to 6 ish.
Your tight squish is really helpful.
Retarding the cam will bleed a little combustion pressure at lower rpm, but will increase pressure above 4,500 rpm (and your Procharger makes more boost with rom so be careful).
Are you EFI or carb?
Detonation is sometimes hard to detect with boost - knock sensors and EGTs help, but familiarity reading plugs (for detonation, mixture, and proper hear range) is especially useful.
mcollinstn is offline
JaniH (01-04-2021)
Old 01-04-2021, 02:23 PM
Carb or holley sniper style efi.
JaniH is offline
Old 01-04-2021, 02:26 PM
JaniH is offline
Old 01-04-2021, 03:26 PM
Valve stem to guide clearance measured, intake 0.0018",exh 0.0021". For my understanding it is fine.
JaniH is offline
Old 01-05-2021, 09:28 PM
mcollinstn's Avatar
Your stem clearance is normal.
If you were looking at a high boost motor, the guide material and stem clearance would be more of an issue, as well as the exhaust seat width and face width at the hot "edge" of the valve.
At your low boost numbers, it's not a huge worry.
You do need to monitor charge temperature (IAT) exiting the throttle body and make sure it stays under 150 degrees. Sometimes you're fine for short bursts, yet long pulls WOT start crawling upwards as the intake plumbing Temps rise. Let that be your signal to back off the sticks a bit or add cooling capacity between the blower and the plenum.
JaniH (01-06-2021)
Old 01-05-2021, 10:04 PM
tripps's Avatar
Default Procharger
How about a 502 with stock cam 1622 Marc 483 lift very mild duration???
tripps is offline
Old 01-05-2021, 10:05 PM
tripps's Avatar
Default Pro
Merc cam
tripps is offline
Old 01-07-2021, 02:26 AM
Originally Posted by GPM View Post
Maybe add an intercooler for safety, are you planning to run a thermostat in the engine ?
I have been considering to use the gm lifter valley baffle. Now when the boost came In the play I definetly going to order the baffle. Thanks!
https://paceperformance.com/i-630462...il-shield.html
JaniH is offline
Old 01-07-2021, 01:09 PM
I had similar engine's to yours but I had dart aluminum heads and vortech superchargers and they never really ran right until I added the intercoolers
green lightning is offline
JaniH (01-07-2021)
Old 01-07-2021, 07:46 PM
GPM
That will do very little to keep the intake air temp down. Procharger recommends not running a thermostat to keep the engine from detonating, along with the intercooler. I wouldn't be surprised to see 180, 190 IAT after about 3 seconds of boost without an intercooler.
GPM is offline
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell or Share My Personal Information -
Copyright © 2023 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
