Originally Posted by underpsi68
(Post 4776787)
I put mine on the sea water pump housing.
What about this specific plug location, (the blue one in the picture) on the PT side water drain vent? The water will have passed through the STB side, the back, the oil cooler and the PT side before coming to this point. I reckon this would enable me to monitor a greater route by attaching it here. What do you think? The pressure should drop more closer to the end of the loop if there's a leak somewhere, right? https://cimg2.ibsrv.net/gimg/www.off...ddb4385df3.jpg |
I have an early 496. The factory sea water pressure sensor in located on the sea water pump. I installed a tee in the pump to add the water pressure gauge.
I went to a local hose shop and had them make me up quality hose the length I needed with my requested ends. Yes the plastic tubing will work but I don't trust it for long term. Do it right, do it once imo. |
Could pull the water pressure sending unit out and put a tee in there.
Originally Posted by Griff
(Post 4776834)
The poly tubing will work fine. My current boat has the original tubing from 23 years ago and never an issue.
I replaced it on previous boat due to clogging. You just have to make sure you don't kink it when you run it from the engine to the helm. |
(Post 4776850)
Originally Posted by Unlimited jd
(Post 4776855)
To everyone contributing here: A BIG THANK YOU!
Now I know how to fix it thanks to you guys! |
Those blue plastic drain plugs have a funny thread and oring setup. I don't think you want to mess with trying to adapt that hole. Like was mentioned, you could T off your factory sending unit on the water pump, or if you have a 1/8" pipe thread drain on one of your coolers.
Originally Posted by 87MirageIntruder
(Post 4776906)
Will I have to drain the gauge tubing for winter to keep it from freezing and cracking? (It is now way below freezing temperatures in the boat...) |
I'm not sure about the freezing question. Hopefully someone who lives in a cold climate can answer that. Sorry
| All times are GMT -5. The time now is 08:34 AM. |
