496 Questions
Thank you! On all of my past 350/260s and this engine I run mercury or quicksilver oil and filters. Got a pile of them when Gander Mountain went out of business and can usually pick up oil when on sale. I looked up plug wires cost and holly cow! Are they connected right into each ignition coil so you’re buying the coil as well??
Many threads on high quality replacement wires for more normal prices. One thread is very recent.
It’s the .060” plug gaps that wear out ignition components faster than they should. I feel like a broken record.
When the exchanger gaskets warp, they won't let the seawater into the coolant side, that's not what they are sealing, it's just the end caps they seal. When the warping happens, they can restrict seawater flow through the cooler and it runs hot then.
If you are dying to replace your plug wires, here is a set some of us have used. I have them on mine now, made in USA Moroso wires for $70. 18-8838-1 84-881698,496-8.1 lr, distributor less ign, Ignition Parts mag star Wire Sets.Ignition Wire Set 120/140 discount high voltage ignition wire sets, s.s. coil core magstar v-6 wire sets, v-8 magstar ignition wires discounted, mercruiser h.e.i.
For spare parts, an IAC valve is common to carry. There's been lots of forum conversations about these as you can get genuine or aftermarket ones. Many caution using the aftermarket ones so I went with OEM for a spare myself.
Will read up on the IAC (Had to google that). Thanks again
Can anyone recommend a good experienced mechanic who will travel to my boat location and has worked on 496s in the southern Delaware/Ocean City MD area? I had all of my service done near Annapolis last year prior to moving the boat. I have a reputable mechanic that I trust, but he does not work on these engines much at all so it is always nice to have someone on retainer that is very knowledgeable with the engine. The boat is stored on a lift with no ability to trailer, so local marinas are not an option for that reason as well as a few other reasons.
yeah I saw that and the website was last updated in 2017. I had to double check this thread date and the site/wires are still recommended but I can’t find the wires on a search. So anyone that had a link to the wires or alternative I’d appreciate it. Thanks.
edited. I did some more searching, the Volvo Penta 3861295 is the same wire as the Merc wire for ~$75 a set from all the posts comparing the two. Everyone said they were identical when changing them. FYI for anyone looking, I think I’ll give them a shot.
