Spark Plug help >
Spark Plug help
Spark Plug help
Old 02-21-2021 | 04:38 PM
Default Spark Plug help
I’m trying to find plugs for my new to me 650 Chiefs.
they have NGK VR5. I’ve looked and can’t find them.
02Formula33ss is offline
Old 02-21-2021 | 05:21 PM
Is there another number stamped in the metal? Not just the one written on the porcelain.
bigfarmer is offline
Old 02-21-2021 | 06:33 PM
I don’t believe so. I’ll have to check again tomorrow.
Old 02-21-2021 | 06:35 PM
Rookie's Avatar
Are you sure it is not the NGK V-Power UR5 2771 plug? That is a common aftermarket head plug.
https://www.ngk.com/ngk-2771-ur5-v-power-spark-plug
Rookie is offline
Old 02-21-2021 | 06:46 PM
That definitely looks like it. Super short
Old 02-22-2021 | 01:30 AM
UR5's are a fairly cool temp plug. I ran them in my 525SC.
Basically the same as an AC R41TS
Griff is offline
Old 02-22-2021 | 06:56 AM
Rookie's Avatar
NGK numbers lower is hotter. It is equivalent to AC R43TS.
https://www.sparkplug-crossreference...ert/NGK_PN/UR5
Rookie is offline
Old 02-22-2021 | 01:15 PM
It was a while ago, but now I remember that I went up one heat range from the stock plugs AC41's because they were fouling too easy at idle. For some reason NGK doesn't use the 5 in the UR5 as the heat range. The NGK 6 heat range is equivalent to an AC43, so by the numbers, the UR5 would be about an AC44
NGK sight also shows they are equivalent to an AC R42TS https://www.ngk.com/search/crossrefe...&br=AC%20Delco
Griff is offline
Old 02-22-2021 | 01:50 PM
SB
Yup, most Merc and performance engine's would use a 6 heat range NGK or maybe if quite cold plug needed a 7 NGK heat range plug.
SB is offline
Old 02-23-2021 | 02:21 PM
Here’s the plug.
