MPI oil filter head. Restriction?
#34
#35
If I want to run the HP 500 thermostatic head, it would be best to force all the oil through the cooler. I wonder if the thermostat side of the cooler can be plugged.
I’ll probably just use the MPI head and just leave it. Lol
#36
I couldn’t live with the restriction in the filter head. The fitting is 8AN but is a little larger than the inside diameter of a 8AN fitting. With that I decided to pick up this:
Fairly inexpensive. I cutoff the shelf on the bracket where the original filter head sat. The new head will be mounted on the upright/vertical surface.
This will give fill flow from the filter.
