Originally Posted by SB
(Post 4786617)
Since that dist is Hall Effect, wouldn’t you be able to use a Tbolt IV/V distributor if you have one ?
Can the Sniper ECU accept a magnetic pick up distr ? If so, delco/merc est/voyager could be used, if you have one. |
Originally Posted by Baja Rooster
(Post 4786576)
Originally Posted by Shotgunn
(Post 4786685)
Holy smokes! way beyond my skill level with a welder. Guess I will just stick with carbs
I’m going to run FAST’s dual channel AFR meter. It’s a little over $500 with 20-foot cables. Being able to see what the engines are doing in the boat is important to me. Next year, maybe FI so the bungs will already be there and ready. |
(Post 4786617)
Can the Sniper ECU accept a magnetic pick up distr ? If so, delco/merc est/voyager could be used, if you have one. There are some workarounds but they’re not supported by Holley. |
(Post 4786685)
I took mine to welder and picked it up a few days later , but if you can`t handle that then yes stick with carbs. |
Originally Posted by TomZ
(Post 4786688)
It can only “control” the HS ignition.
You have a link for the documentation ? Thanks. |
Here's a link to the installation manual:
https://documents.holley.com/199r11031r.pdf A quick look shows that it can control a MSD magnetic pickup distributor with CD box after locking out the advance (duh) and installing an adjustable rotor. That was not what the EFI System Pro told me. Probably just a sales-related comment because I had mentioned that I wanted to stick with my distributor. He mentioned the plug and play Hyperspark system though the documentation only shows Dual-Sync. The installation manual does not really go into deep timing control. |
I appreciate all you more knowledgeable people discussing this so i can try & follow along. :)
(Post 4786758)
Also says other (than Holley’s) hall effect distributors may be able to. So, possible the Merc IV:V dist could to. Obviously timing module eould not be used. Proof would be in someone trying. |
| All times are GMT -5. The time now is 04:15 AM. |
