Low compression big block >
Old 04-13-2021 | 07:52 PM
tripps's Avatar
Default Low compression big block
Here goes ,got a 539, 4.125 stroke 4.560 bore has dished blower pistions ,using chevy iron heads 119 cc single 850 need cam advice ,have a procharger for it but want to run with low comp first probably 8 -2 -1 compression any thoughts ???
tripps is offline
Old 04-13-2021 | 08:20 PM
GPM
Pro Chargers seem to like 9:1, 112 LSA. What are you planning to use, hydraulic, solid, flat tappet, roller ?
GPM is offline
Old 04-13-2021 | 08:35 PM
SB
THis is not a suggestion. Just a WAG and see how close i am to those more experienced in a combo like this.
240, 248 112 lsa
maybe 240, 250 112lsa
SB is offline
Old 04-13-2021 | 09:18 PM
mcollinstn's Avatar
What dish size (in cc), and how far down in the hole are the pistons? You may not have the CR you think.
mcollinstn is offline
Old 04-14-2021 | 02:38 AM
tripps's Avatar
Default Cam
Deck is zero not sure of ccs of pistions,looking for solid roller,741?? Something easy on parts
tripps is offline
Old 04-14-2021 | 07:57 AM
Crane 651 works pretty well NA and boosted.
snapmorgan is offline
