any master aluminum TIG welders here? >
Old 04-22-2021 | 08:42 AM
F-2 Speedy's Avatar
Is the car an original Cobra ?
F-2 Speedy is offline
Old 04-22-2021 | 08:54 AM
Run another line of shielding gas to the underside of the welding area.
30ftpanther is offline
Old 04-22-2021 | 10:46 AM
yes it is an original cobra. it has been raced since new in '64 so it was not treated nice. the aluminum is wrapped tight around the steel tubing so I am sure that it is pulling some heat and it seems to mess with the arc if the crack is a little wide which some are.
may try to get some shielding gas behind it but it is not like a tube you can close off so not sure how to contain it.
compedgemarine is offline
Old 04-22-2021 | 11:50 AM
Most likely the aluminum is oxidized/corroded around the steel part, the aluminum acts as an anode for the steel.
Falcon is offline
Old 04-22-2021 | 12:18 PM
Can you get a piece of aluminum behind to use a back up plate?
fbc25el is offline
Old 04-22-2021 | 01:30 PM
If your wanting the welds to look like bird **** then Im your guy.
Eddienel is offline
Old 04-22-2021 | 01:33 PM
i can't think off anyone that would choose an actual, original alu. body cobra to upgrade their welding skills on....make her beautiful!
speicher lane is offline
Old 04-22-2021 | 01:45 PM
RSCHAP1's Avatar
Have seen a few guys use a shop vac to draw shielding gas around areas to be welded when there wasn't a good way to get behind or under it.
Maybe a "band aid" if nothing else helps.
2nd the thought of being quite a project to polish welding skills up on
Good luck with it all
RSCHAP1 is offline
Old 04-22-2021 | 03:24 PM
hey, no guts, no glory!
Old 04-22-2021 | 03:25 PM
Sent you a pm with name and number, He's your guy, one of those welds tin foil back together types.
great guy, he'll talk to ya, call him up
outonsafari is offline
