2000baja boss hamner >
Old 05-01-2021 | 11:53 AM
Default 2000baja boss hamner
I have a 2000 Baja boss hammer I just replaced the alternator and the battery hooked everything back up and I have absolutely no power to anything but my outdrive
Bannanaboat2000 is offline
Old 05-01-2021 | 12:05 PM
F-2 Speedy's Avatar
what engine, 502 mpi ? is there a fuse on the starter might of blown, red reset button on top ? did you reset it
F-2 Speedy is offline
Old 05-01-2021 | 12:30 PM
How do I reset it
Old 05-01-2021 | 01:27 PM
Just go back over everything you took off and then put back on...give it a good visual. Make sure you have the pos and neg hooked up correctly...not a slam by any means, it HAPPENS.
bajaman is offline
Old 05-01-2021 | 04:55 PM
Got a test light, easy to check where you have voltage or not?
PA.WOODCHUCK is offline
Old 05-02-2021 | 11:12 PM
Originally Posted by Bannanaboat2000
How do I reset it
You have to replace it. Also check the 50 amp breaker on the engine.
Have you checked to make sure its not your kill switch?
Griff is offline
