Holley 4 barrel gaskets >
Old 05-25-2021 | 03:23 PM
Default Holley 4 barrel gaskets
So i have a list around here somewhere,
things i never did, things that didn't need doing, and things i probaly shouldn't have gotten myself into.
added to to all 3 today, took the carb off and took the carb apart.
probably didn't need to, it was clean inside except the lower bowel ( inboard engine at 12* angle) had just a touch of crud on the bottom.
damn thing probably woulda coughed up a lung for a couple tanks then worked it self out.
The metal parts are chem dippin right now, all the electric engine components and harnesses are shipped, now i got myself into it.
at the top of the picture next to the electric choke, that (vac 2ndary), the accelerator pump and the choke did not go into the dip, just the bowels, nuts, studs, the spacer and carb body will have to be done seperate and no jets or screws were removed or turned.
Thanks guys, Where can i get gaskets ?
Last edited by outonsafari; 05-25-2021 at 06:12 PM. Reason: Spelling and clarification
outonsafari is offline
Old 05-25-2021 | 04:23 PM
SB
Call:
https://www.aedperformance.com/parts/rebuild-kits.html
Then buy from them or get part #and order from your favorite soeedshop.
SB is online now
Old 05-25-2021 | 06:14 PM
Thank you SB
Old 05-25-2021 | 08:06 PM
AED is great but personally I would buy an entire Holley rebuild kit from somebody like Summit.
BillK is offline
Old 05-25-2021 | 08:43 PM
switch it to eldebrock 1409 or 1410 they definitely run better in an inboard set up and have way better idle circuits
boostbros is offline
Old 05-25-2021 | 09:33 PM
Rookie's Avatar
Is this a serious post or are you just messing around? A $10 gasket kit or a new $500 carb?
Rookie is offline
Old 05-26-2021 | 10:00 AM
I had dual double pumper carbs on a T-bucket I built and they were a pain. They'd always leak where the fuel tube is inserted between both bowls. Replaced them withremanufactured dual Carter carbs and all the problems went away...including the difficulty with cleaning them and finding gaskets.
Barnacle Bill is offline
Old 05-27-2021 | 12:37 PM
I have had both. I'd fix the Holley. It's jut a gasket change and cleanup.
NHGuy is offline
