Mercruiser 496 crank no start
GRAb a free loaner fuel psi tester from Autozone on your way home too.
Ok so I tested the fuel pressure and it was 40 psi while cranking and I swapped the relays on the top of the engine and it still won't start. I call a local service center near me to get it scanned but the soonest they can get me in is in two months. Any other suggestions?
SB (06-02-2021)
Where are you located?
No spark though. So, lets look into this. Sorry for basic question but have to ssk - how did you check ?
SB (06-02-2021)
I don't know the ins and outs of the 496 ECM but I know there's a crankshaft sensor and a camshaft sensor. Wouldn't surprise me to find out crank sensor measures RPM and cam sensor controls ignition.
On a side note, there are a few different types of both sensors so make sure you get the one for your eng serial number if replacing.
