Merc 8.1l 3200rpm max?
2006 Mercruiser 496
engine only revs to 3200 under load, additional throttle has no effect.
Mercury vesselview
Throwing a code for "TPS Sensor adapt A"
124-legacy
Swapped sensor, no change.
Unplugged sensor and it throws the standard "tps sensor" fault
anyone have any insight?
Ps. Ive already done plugs, coils, entire fuel module/pumps/filters, swapped ecm between engines with none solving my problem.
Mercury vesselview
124-legacy
2006 Mercruiser 496
Mercury vesselview
124-legacy
Mercury vesselview
124-legacy
If digital maybe in your dts throttle control unit
Engine was cutting in and out, it would start accelerating to 4000 buy the cut back to 3400, back and forth mostly randomly. Now it's pretty solid at 3200 Throttles are cables, other motor runs great so unlikely a gas problem as they share a tank
