588 block pressure >
588 block pressure
588 block pressure
Old 06-08-2021 | 09:14 AM
Default 588 block pressure
One of my 588 blower motors blows out the oil breather on valve cover makes a big mess and causes my blower belt to slip. It has a rubber tube that goes to a small holding tank. i assume to much pressure in case can a pressure relief value be installed. Any ideas would be appreciated
588 block
B&M Mega Blower
6 lbs of boost
tks again
Bad to the bone is offline
Old 06-08-2021 | 09:31 AM
articfriends's Avatar
leakdown test, something hurt ring seal. for now, put largest vent hose you can on to ;largest vented tank you can. Extend breathers taller if possible
articfriends is offline
Old 06-08-2021 | 02:43 PM
Thanks for the followup
