525SC fuel pressure
My father has a 2000 checkmate 259 with 525sc, chiller and higher boost pully, 1050 dominator, he just installed a Sierra 18-8860 fuel pump, seeing 7psi at idle and dropping to about 3.5 psi at W.O.T boat is running good but hes worried 3.5psi is too low? He doesnt remember the pressure being this low in past.
I read somewhere where Mercruiser states 3-7 psi @ 1,800rpm, I think hes seeing about 6psi @ 1,800rpm Thoughts? https://cimg7.ibsrv.net/gimg/www.off...615f34cf93.jpg |
IMHO, 3.5 psi is too low at WOT.
I use one similar to this one then use an Aeromotive adjustable regulator to set press to 7.25 psi. Works great. https://www.cpperformance.com/p-1328...ock-chevy.aspx |
Originally Posted by zz28zz
(Post 4793576)
Pay no attention to me BUT... the fuel bowl is full at WOT with almost any kind of pressure. If the carb bowl was not full the pressure would be below 1 psi
Any pressure means the pump is outputting more then the carb can use |
Originally Posted by AllDodge
(Post 4793620)
Any pressure means the pump is outputting more then the carb can use Makes total sense, i thought same at some point, but it is not true in actuality. Under 5 psi things get a little interesting. Under 4 worse, and under 3 really not good. |
I run the blue KE mechanical fuel pump on a built 525sc with no problems. Though I did increase the size of the fuel line and pickup.
(Post 4793620)
IMO, I would want to see at least 5# of fuel pressure at WOT.
(Post 4793870)
Whenever a liquid flows thru a restriction (needle/seat assy) there will be a press drop. The more flow you have, the more of a press drop you will see. At some point, fuel will be taken out of bowl faster than it can be replaced due to this press vs restriction relationship. Since the restriction is basically fixed (once float drops), you'll have to increase press to maintain sufficient flow. Around 7 psi has been generally accepted as the optimum press for many many years.
This is low pressure issue, and don't agree and appears I'm alone on this. Could prove it by setting up a fuel pump, filter, lines and carb inlet (no fuel bowl, recirculation maybe) on a test fixture of some sort. Start pumping and see if the pressure can get anything close to 3 psi with free flow . |
(Post 4793920)
Understand what your saying, rural water companies have main water pressure above 100 psi to keep high flow up, and regulators on houses to bring pressure back down.
This is low pressure issue, and don't agree and appears I'm alone on this. Could prove it by setting up a fuel pump, filter, lines and carb inlet (no fuel bowl, recirculation maybe) on a test fixture of some sort. Start pumping and see if the pressure can get anything close to 3 psi with free flow . The needle/seat assy provides some restriction even when it's "fully open." I agree that with free flow there will be very little pressure achieved, but it's not free flow when there's a restriction involved. To achieve more flow thru a restriction, you will need more pressure. Your logic is sound, but I think you are underestimating the effect of the restriction caused by the needle/seat assy. |
| All times are GMT -5. The time now is 11:19 AM. |
