Lost rpm
#32
Bravo boat? Bad coupler maybe?
I know you said the lazy engine won't rev. But on the flip side, no load no boost for the most part.
Other than that, fuel issue? Are all the fuel components you dyno'd it with the same as in the boat?
#33
Yes Bravo boat with brand new couplers. Engine will spin up to 4000 rpm and at that rpm should be making around 4 psi boost. If the procharger is spinning at that rpm it HAS to be making boost - its a mechanical pump that's driven by a belt off the crank. Anyone know if there's a way to actually test the procharger? We've done a leak down on the motor and everything checks out perfect. Either the blower isn't producing boost or its being lost somewhere. I've pressure tested all the tubing and the chiller and there's no leak.
#35
And no it doesn't HAS to make boost. Put a open ended tube from the supercharger just into open air with a pressure gauge in the tube, spin the thing 50,000 rpm and Ill bet you see no "boost" on the gauge.
So the boost seen in the past on your gauge on that engine was the gauge pressure seen at a typical rpm with a typical load at that rpm on the engine.
Got a turbo'd diesel truck with a boost gauge? Drive along flat ground at whatever speed, make note of the boost, hit a steep hill and don't downshift or let it downshift, try to maintain that same speed, watch the boost rise.
Otherwise, have you tried at least to run both N/A with out the belts, see if you can achieve the same rpm on each engine with the same props?
And yeah I'm aware the tune may be off running N/A
#37
#38
#39
