Im not sure what chargers your running?? My M-3 will sit around the 2 PSI mark at about 3100 RPM, to me the boost should be coming in sooner then 4000 RPM (granted I dont know what pulleys/blowers your actually running) Whats the back of the boat look like? Soot?? What do your plugs look like?? Have you watch timing on a timing light to see how it reacts?
It has to be an ignition problem or a fuel problem, if the motor is sound inside.
Didn't read all posts, but did you do a compression test hot.. I had a problem with detonation and it broke the ring lands on the piston before. It wouldnt show up on a cold comp test. |
Originally Posted by resurrected
(Post 4796524)
The fuel you are using is crap and the knock senors pulling them back? Just throwing out stuff because I don't think there is much left
Originally Posted by Ontariocheckmate
(Post 4796529)
Originally Posted by bossbrakes
(Post 4796538)
Hmmm definitely very confusing for sure... the only time Ive seen a similar issue with my boat was when I was trying different props this year, Just simply wasnt putting out the boost or pulling the proper RPM... swap back the props everything was good. You havnt changed your props though at all correct?
(Post 4796627)
How about full throttle travel at the TB?
(Post 4796640)
Thanks everyone for all the suggestions - I've gotta get this figured out! |
I can't wait to hear the solution! This is a head scratch-er for sure. Keep digging, the season is too short to be head down @$$ up in the bilge all summer!
| All times are GMT -5. The time now is 04:16 PM. |
