Got screwed on a boat ..Need help
#31
( being that you’re facing the input shaft of the drive) and ( while still turning the input shaft) push the shift link into the shift link cavity and you should feel it snap into gear and the prop shaft should start turning in the direction for what would be forward for a r/h rotation prop ( which you have)
#33
#35
My first comment was in relation to changing the lower determines if its a B1, B2 or B3. Was not talking about gear ratios, hence why I posted the compatibility charts
My second comment based on what you talked about upper gear ratios and no mention of lower B3.
Cool boat!
