Got screwed on a boat ..Need help
Bought an 89 marlin 26 offshore boat with 454 and bravo one . First two minutes on lake would not shift into forward. Pulled outdrive , something is jacked up in outdrive . They are 2500 to rebuild and 3000 for refurb.
question could I bolt a bravo 3 upper on the bravo one lower and it work ? I know they are different ratios … if they bolt up how would it affect my performance
do you know about these boats ? I couldn’t really find any information .
it won’t let me post pictures until I have 10 posts , I just joined the forums
I’m in Tennessee
If you broke your last post down into individual sentences, you would be at 6 posts.
re drive - oil condition, metal on magnets, leaking seals ( pressure test drive is best), ensure all the splines ( prop and input shaft) are arrow straight and not twisted, u-joints are tight, drive turns FNR, corrosion/ cracked cases etc.
Your next post will be saying you bought a bad drive.
The difference in a "standard" B1, B2 and B3 is the lower ONLY. The upper is all the same
Now for the BUT
The lower will bolt to the upper provided they are compatible. Basically after 1993 your good
