350 mags causing issues
I have a 2000 donzi 28zx with twin 350 mags, and the person that winterized it didn't get all the plugs in from winterization! I keep taking on water and I'm sure I'm missing some plugs. Does anyone have a diagram as to where they are and or how many there are per engine? I did order a cone kit to hook up water but want to get it fixed before if possible.
Thanks!
Thanks!
MPI with the one point drain?? All hoses attached?
Start at 20:35 shows the locations of the 4 plugs - name the 2 B*tchy ones behind the cool fuel.. (The vid doesn't show the plugs on either side of the block as engine in vid doesn't have One Point)....(have also seen a cooler split for hard to trace water leaking into bilge)
There are differences by year but my 2001 350s have:
1 per side of engine block
1 at fuel cooler
1 at water pump elbow
1 at each exhaust manifold bottom
so, 6 each engine for mine...
but yea, run it on a hose and see what leaks lol
1 at fuel cooler
