Merc 383 6.2 cam needed for stock ECU >
Old 07-02-2021 | 02:00 PM
Default Merc 383 6.2 cam needed for stock ECU
Hi - busy rebuilding a 383 mag, came came out as 862562 which matches all the 377 and so on models. Is there a cam that will match or replace this without having to do anything to the pcm module?
I did get this info on another thread:
Crane 104224
Lift: Intake @Cam 301 @Valve 452 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 310 @Valve 465
Rocker Arm Ratio 1.50
Cam Timing: -- @---
Lift: Opens Closes ADV Duration
Intake --- --- 270 °
Exhaust --- --- 276 °
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 0.0 BTDC 34.0 ABDC 107 214 °
Exhaust 47.0 BBDC (7.0) BTDC 117 220 °
This information is from bobl/FTM.
Thanks goes to him.
Can someone point me in the right direction?
"Thanks!
CamaroMan is offline
Old 07-02-2021 | 02:19 PM
may want to try bullet cams,you can send them the cam and they will copy it.
sutphen 30 is offline
