Merc 502 Timing Issue - any help. >
Old 07-13-2021 | 07:01 AM
Originally Posted by Griff
Possibly worn dist gear and/or cam gear is much more likely than a timing chain issue.
I thought that but what about the low compression? I put my finger over #2 and it didn’t blow my hand away at all.
This week I’m going to investigate and get my compression numbers and check for loss of vacuum.
srdrago is offline
Old 07-13-2021 | 07:13 AM
Do leak-down test for compression loss. Borescope on your camera will tell a lot about your pistons/valves. Can also be helpful about your cam.
Good luck.
GLENAMY 242SS is offline
Old 07-14-2021 | 09:38 AM
Good luck.
Ya going to get all compression readings today, check for any other noticeable issues, scan it with a Rinda tool and see if anything shows. Might do a smoke test to see if anything shows from that.
srdrago is offline
Old 07-14-2021 | 05:23 PM
Got the following compressions.
1-130
2-25
3-38
4-95
5-75
6- 50
7- didn’t check.
8- 80
srdrago is offline
Old 07-14-2021 | 05:26 PM
1-130
2-25
3-38
4-95
5-75
6- 50
7-
8- 80
Might as well stop there. Engine needs to come out and be torn down to evaluate further.
Griff is offline
Old 07-14-2021 | 05:38 PM
F-2 Speedy's Avatar
that might be a broken cam shaft
F-2 Speedy is offline
Old 07-14-2021 | 08:40 PM
SB
SB is offline
Old 07-15-2021 | 06:38 AM
oh ya. Can’t get it to the garage for couple days. Going to start tearing it down meanwhile to prep to pull out.
don’t think cam shaft being broken. The router spins, starter spins and front belts spin. So from front to back it’s intact.
anyone know if I can get the timing cover off without dripppig the pan?
srdrago is offline
Old 07-15-2021 | 07:31 AM
You may be able to pry the timing cover off of there, but if it is a gen 6 cover it will most likely break the corners off the timing cover. It isn't really feasible to do it without dropping the pan and dropping the pan in the boat is all but impossible. You would be much better off to spend the 45 minutes it takes to remove the engine.
snapmorgan is offline
Old 07-15-2021 | 08:36 AM
If #7 really has 0 pressure 95% chance engine has to come out to fix it. Much easier to work on on a stand.
liberator221 is offline
