Catastrophic Engine failure. 454 gen 6
#91
#92
You bought a multi keyway timing set and cam degree tools for ?
Merc also install their bbc ‘blue motor’ Crane cams 5* advance.
More midrange, less overap after top dead center, to name a few reasons, I’m sure.
#93
I advanced my cam this morning. Here is what I came up with moving the crank sprocket 2 degrees advanced.
Looks like all is right with the cam world now.
Duration @ .050" (2* crank advance)
Exhaust 49-5+180=224*
Int -2+47+180=225*
Valve opens
Exh 49*
Int -2*
Valve Closing @ .050"
Exh -5*
Int 47*
Valve lift
Exh (.284")
Int (.284")
Max Lift. 482.8
CL
exh (167+63)/2=115
int (63+167)/2=115
LSA 115*
#94
I checked the real ptv clearance and squish tonight. I threw a light spring on the intake and a once torqued down head gasket that's the same as the ones I'm running. .102" int PTV and .066" squish.
#95
Can you explain how you calculated the 109* ICL? This is what I calculated. I was calculating lobe c/l I thought. I calculated it by coming down .050" off the max lobe lift (.284").
CL
exh (167+63)/2=115
int (63+167)/2=115
Also, why did I need to advance 2*? A stock timing chain doesn't add 2* so does that mean they're all running retarded?
CL
exh (167+63)/2=115
int (63+167)/2=115
#96
Finally found the time to finish her up. Went out tonight and she's running like a champ. Brought her up to 35, but I didn't want to push her too hard yet.
I started her on the hose and broke her in then changed the oil and filter. Set the timing to 8°. I have a short list of things I want to dial in on the boat, but I can finally enjoy her at least.
Thanks again to all you guys that helped out.
#98
#99
