I guess I will go back to mechanical pump
messed around trying to get better psi now shows 0 psi |
Why change a coil and fuel pump because of an overheat caused by a broken belt????
Originally Posted by Griff
(Post 4798880)
I had low fuel pressure …I checked spark because of sputtering … all my spark plugs look black and burnt up ..so decided to go ahead and change plugs and upgrade coil |
I think my mechanical fuel pump got damaged because block got so hot
Originally Posted by Guitarhead
(Post 4798882)
agree electric pumps push better than pull... keep us posted... good luck |
Originally Posted by flashgordon
(Post 4798885)
compression test or leak down..........
Hate when my rod get’s stuck.
Paramedic or family doctor ? |
Rod is stuck? The rod that rides cam lobe and operates mech pump? If so, that would explain low fuel press.
Curious, have any info on the fuel pump such as spec, name, part number? That doesn't look like what I would consider enough to feed the BBC?
Originally Posted by PA.WOODCHUCK
(Post 4798904)
https://www.edelbrock.com/universal-...e85-17303.html |
| All times are GMT -5. The time now is 05:03 AM. |
