Engine stalls stalls when put Into gear! >
Old 08-15-2021 | 12:22 AM
Default Engine stalls stalls when put Into gear!
My port side engine drops rpm and dies slowly when I shift into forward, 90 fountain twin carved 509 with bravo drives imco uppers. Happens to one side only! Any help suggestions would be greatly appreciated.
NickSkyline is offline
Old 08-15-2021 | 07:01 AM
bencini231's Avatar
I have a friend who had this same issue earlier this year on one motor. His ended up being a bad fuel pump. Not sure if that is the same in your case, but its very easy to diagnose.
bencini231 is offline
Old 08-15-2021 | 07:02 AM
F-2 Speedy's Avatar
if its EFI ID start with the IAC
F-2 Speedy is offline
Old 08-15-2021 | 07:59 AM
SB
I’ll guess carved = carbed ?
New problem ? Was it running fine all this summer and then this showed up ?
What have you checked thus far ? Do you know how to check timing and clean out the carb ? Check/replace spark plugs ? Etc, etc ?
SB is online now
Old 08-15-2021 | 08:21 AM
F-2 Speedy's Avatar
probably so SB, I didn't know what a carved 509 was
Old 08-15-2021 | 10:59 AM
yes carbed motors, I just bought the boat and got her on the water yesterday. Timing was set few days ago by a local reputable shop. Boat sat for over two years prior.
Old 08-15-2021 | 11:00 AM
carbed lol, sorry auto correct
Old 08-15-2021 | 11:01 AM
Plugs, new msd coils, timing set, new water separators all replaced.
Old 08-15-2021 | 11:02 AM
has electric pumps. Pressure is same on boat motors looking at the gauges
Old 08-15-2021 | 11:12 AM
F-2 Speedy's Avatar
did you pump out all the old fuel ? Id think those carbs would need a bebuild with old gas setting in them for 2 yrs
