Harmonic Balancer Timing Mark Moved >
Old 08-26-2021 | 01:16 PM
Default Harmonic Balancer Timing Mark Moved
Anyone have this happen? Where the mark slips or turns and you don't get correct timing?
Seahawk 2000 is offline
Old 08-26-2021 | 01:42 PM
SB
Yup. Older motors. I remember in the 80's when a bunch of small block one's actually seperated. Boy where those noisy !
SB is offline
Old 08-26-2021 | 02:08 PM
F-2 Speedy's Avatar
I saw one come through the hood of a 66 Nova-caine at about 8,000 rev's
F-2 Speedy is offline
Old 08-26-2021 | 05:13 PM
Yup, I replaced at least 4 of them back in the 90's when I worked on cars for a living. If you let it go past the point of no longer having rubber in there, it will start creating a tons of tiny metal shavings. Then an unsuspecting mech comes along with his air ratchet pointed the wrong way and winds up with a bunch of shavings embedded in both eyes and a trip to the ER. Not a fun as you might think..
zz28zz is offline
Old 08-26-2021 | 06:47 PM
Yep time for a new harmonic balancer, the outer ring slipper in reference to the crank. After time the rubber holding the two together fails. As stated above a failure at 8000rpm is exciting to say the least and on a boat possibly deadly.
carnutsx2 is offline
Old 08-26-2021 | 07:40 PM
The stock balancers are not made that great. The rubber deteriorates, I can defiantly see them slipping.
jeffswav is offline
