Gen VI 500HP >
Gen VI 500HP
Gen VI 500HP
Old 10-03-2021 | 08:32 PM
Active Streak: 30 Days
Default Gen VI 500HP
What is the correct Service Manual for a Gen VI 500HP Carbureted Motor? Thanks in advance.
Helmwurst is offline
Old 10-05-2021 | 08:01 AM
1996 and up was Gen 6. #3 for Carb. Getting year correct is key.
Pismo10 is offline
Old 10-05-2021 | 08:03 PM
I have the #3 Service Manual. I do not see any reference to the Gen VI. Ex; Timing cover only has 6 bolts, what is the torque. Are all the bearing and ring tolerances the same on the Gen VI as the the Gen V? Thanks for the input.
Old 10-06-2021 | 06:18 AM
The date on your copy of manual #3 is before 1996 probably.
Pismo10 is offline
Old 10-06-2021 | 07:38 AM
Yes it is. I need a newer version that covers the GenVI. Anybody out there have one they don't need anymore? PM me. Or text, 816-eight 0 four, 63 one one.
Old 10-06-2021 | 07:47 AM
The only difference to a gen 6 is the timing cover.
Unlimited jd is offline
Old 10-06-2021 | 08:14 AM
There's a lot of other differences between a Gen V and Gen VI motor. Are you just saying what the difference is with the pre and post dated manual?
HawkX66 is offline
Old 10-06-2021 | 08:48 PM
The more I read in the #3 manual the more is missing. There is nothing in there about the knock sensor and the module behind the rev limiter. Any tech's out there? What do you reference when working on these engines? Still looking for a #3 manual that covers these Gen VI motors. Will stop by one of the shop locally on Friday and see if I get an answer.
Old 10-06-2021 | 09:03 PM
Merc #16 454/502. Merc #11 Bravo Stern Drives
HawkX66 is offline
Old 10-06-2021 | 09:33 PM
Your manual was probably printed before the TB V ignitions came out.
Griff is offline
